Letter 41078
Powder paint removal from threaded weld
nuts on sheet metal
We retap threads in weld nuts on sheet metal parts that have been
powder painted because bolts break off in the painted holes. This
leaves steel shavings on parts causing much paint scratches. What is
best/cheapest method: to prevent paint in threaded holes with plugs
or removal after paint with taps or brushes or is there other
options?
Edward Lammy
Denyo Manufacturing Corp - Danville, KY, USA
Several vendors sell silicon pull plugs that are made especially
for powder coating. Most will send you a sample of 10 - 20 plugs for
you to try before you buy. They are reuseable for a while. easy in
and easy out.
The best possible solution is to go for Silicon rubber bushes of
suitable size(tapered).Just insert the same in the threaded hole
after pretreatment process.Remove after baking.Whatever powder
sticked on the bush will come off easily with gentle finger
squeezing.Recycle the same for next lot.
With Regards,
S.Thiagarajan
- Dubai, U.A.E.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
