Letter 41073
Alodine Coating
One of my customers is returning parts to us to trim the ends. The parts have been cadmium plated already and they state that "After trim, vendor needs to alodine exposed ends".
In my research on Alodine it appears that it is not just something that can be painted on the ends and that it is for Aluminum. These parts are made out of music wire.
Is there a pen or paint brush method that can be used to Alodine the cut ends? And can alodine be used on music wire?
Terry Austin
spring manufacturer - Stanton, California
Alodine is a Henkel tradename for chromate conversion coating processes. Although Henkel certainly has chromate conversion coating processes for aluminum that go by the Alodine tradename, they have chromate conversion coating processes to be applied to Cadmium plating that go by the Alodine tradename as well. But in any case you cannot chromate conversion coat bare steel.
finishing.com
Brick, New Jersey
May 14, 2009
I have been researching Alodine and wonder if Trisodium Phosphate [link is to product info at Amazon] (TSP) can be used prior to using Alodine with the same results as other methods?
Bob
Bob McKellar
- Entiat, Washington
May 18, 2009
Hi, Bob. I wouldn't do that. It may be possible to get the cadmium plated surface active by scrubbing it with TSP and a tampico brush (especially if it's more of a paste so it has some polishing action), but I think you don't want to scrub cadmium because it's a biocumulative poison.
Ted Mooney
finishing.com
Brick, New Jersey
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
