Letter 41052
Deoxidising after Anodising and prior to
Colouring
I am having some difficulty colouring Anodised Aluminium and
suspect I should be using a Deoxidant immediately prior to Colouring.
Any suggestions for a suitable Deoxidant.
David Rean
Small batch Electroplating & Anodising - Ulladulla, N.S.W.
Australia
I've never heard of that, David. Rather: pretreatment, anodize,
dye, seal (with rinsing in between each step).
finishing.com
Brick, New Jersey
The nitric in the deox will 'open up' the pores and allow better
dye absorption in some cases, usually castings.
Bill Grayson
metal finishing - San Jose, CA, USA
Thanks, Bill. I know of dilute nitric acid being used as a rinse
aid after anodizing, supposedly displacing trapped sulfuric acid. Is
this "deox" solution stronger, or is it also very dilute? Thanks.
Ted Mooney
finishing.com
Brick, New Jersey |
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
