Letter 41038
How about to destroy the Ferricyanide
We have a kind of waste water that contains both Cyanide and
Copper. We generally use bleach to pretreat it and Electrocoagulation
system to treat it.However, the Ferricyanide is still there. I wonder
if we have any better way to destroy or remove the Ferricyanide
except put sodium metabisulfite in it.
Randy Guo
Waste Treatment - Vancouver, B.C. Canada
We usually have from 1 to 11 ppm of ferrocyanide in our
wastewater, and this process works to remove it.
Adjust pH to 11.3 with caustic, and pump in industrial strength
bleach (12.5%) until the ORP reading is 500 to 600 (for our first
couple batches, we went to only 450 to 500 and we found this
inadequate, and ended up doing the entire batch over again). Going to
550 or 600 may be required to fully oxidize ferrocyanide to the
cyanate. Allow to react for an hour.
Adding 40% sulfuric acid through a funnel attached to a 2' long
hose, in order to introduce it well below the surface of the liquid,
adjust pH to 8.75 (do this cautiously, and slowly, so as to not
overshoot the pH target and release chlorine gas). Next, add more
bleach until the ORP reading is 800 (this oxidizes cyanate to
nitrogen and carbon dioxide). It is possible that you won't have to
add much more bleach at all, if the ORP is found to be 800, after
achieving pH 8.75. In this step, we have observed paradoxical
behavior, so if adding bleach appears to lower the ORP, invest time,
and bleach, and hope to eventually get there. Others have noted this
paradoxical behavior in the first step, but we have not (we've seen
it in this second step on some occasions). Allow to react 90 minutes
beyond the time you achieve 800, or more if needed to do this
oxidation step.
Next, pump in magnesium bisulfite solution a shot at a time, and
instruct a second person to add caustic to keep the pH at about 8.2
to 9.2 (the goal is to keep pH at 8.75). The bisulfite will lower pH,
and the task is to counter this with caustic adds, to maintain pH at
8.75. Good pH control is important to this and all steps. Go to a
target ORP of 200. Sneak up on it toward the end, since once you
reach 300 it will not require a lot more. This reduces bleach to just
simply sodium chloride. Our local chemical distributor found the
magnesium bisulfite at Hydrite Chemical in the midwest, available in
plastic drums. Magnesium contributes to the efficacy of the process,
so sodium bisulfite may not work at all.
We next add 7.6 ml per gal of wastewater, of a coagulant, as a 10%
solution mixed into water, to the batch. We have found this product
at Chemetall Oakite (Enprox
8412). Mix this for 15 min into the batch. Finally, adjust the pH to
10.6, or what is appropriate to the product next used. The batch
needs to now have a flocculent added, at 3.8 ml/gal, also as a 10%
solution. We have found this product at Oakite, too (Enprox 8440).
Allow to mix for 15 minutes, and then settle the tank. We are getting
total cyanide (e.g. ferrocyanide) at non-detect, in the supernate.
David H. Duncan
- Ponderay, ID, USA
To the best of my knowledge, these iron cyanides are not
amenable to chlorination. If your lab runs the cyanide test via
distillation/colorimetric method, the sulfites you add will generate
SO2 during the distillation. This passes over into the sparger
solution along with the HCN. The first step of the colorimetric
procedure is a chlorination with Chloramine 'T'. If there is enough
sulfite in the sparger liquid to neutralize it all, a false negative
results. I have personally been skunked by this on two occasions.
Once, I got a really nasty surprise when the inspector came along and
cited me because my "non-detect" effluent was in fact, in
violation.
I developed a precipitative method for removing these
complexes.
A careful technician will check the analytical prep after the
Chloramine 'T' addition with KI/
starch paper [link is to product info at Amazon], and add
excess if required. Or, the finish could be run by ion selective
probe, which is not subject to this interference.
Dave Wichern
- The Bronx, New York
Yes, that's correct, iron cyanides are not amenable to removal by
chlorination, as cyanide is. The procedure above uses bleach to
oxidize ferrocyanide all the way to iron cyanate, which is then
further oxidized to decomopose the cyanate to elemental nitrogen and
carbon dioxide. It does require a fair amount of bleach. Thanks for
the tip on sample prep!
David H. Duncan
- Ponderay, ID, USA
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
