HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => letter 41035
Cast iron cleaning and filler++++++ I have a cast iron bell needing a thorough cleaning and a few pocks that need filled. - New York, NY ++++++ You can use 5% ammonium citrate solution(mixture of 50 gm citric acid/1 lit water and add some ammonia,pH must be 3,5- citric acid without ammonia works too ).As filler you can use mixture of iron dust and some epoxy glue.Good luck and hope it helps! Goran Budija- Zagreb, Croatia |
