Letter 41023
I need clear shiny aluminum surface after
bright dipping or etching process
I am working on aluminum finishing but I have a problem that after
bright dipping there is a cloudy surface apearing on the articles and
that makes color differences in coloring.
M.Saqib
aluminum anodising - Pakistan
I believe that you have correctly identified the problem of the
color differences as being caused in or before the bright dipping
process, M. So the next step is to determine what, if anything, is
wrong with the bright dipping. If you care to provide any details
about the bright dipping perhaps a reader can make suggestions of
what needs correcting.
Meanwhile, have you examined the racking and found any correlation
between the dull areas and their position in the brite dip tank? Good
luck.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
