Letter 41022 Brittle Nickel Plate [South Carolina]June 6, 2006 I am running a high speed sulfamate nickel process plating 18 gauge wire. 350-450 ASF, 16 oz/gal Ni, 140F bath temp. S-rounds for anodes, 1.5 oz/gal NiCl and boric acid to saturation in anode bags. When plating the wire to 27% Ni by weight, I only get about 6 weeks life out of the bath before the plate becomes so brittle the wire won't draw. I have analyzed for ammonia and have found as much as 600 ppm. Anybody have any ideas on the cause and/or the solution? Kurt Sammons
First of four simultaneous responses -- June 7, 2006 The facility you are working at was plating 27% nickel with indefinite bath life 20 years ago. I know because I ran the operation then. Apparently personnel changes have caused the procedure to be lost. Make sure you have enough anode area and keep the operating temperature down. The problem isn't ammonia, it is sulfate from sulfamate decomposition.
Second of four simultaneous responses -- June 7, 2006 You do not say what your pH is or how hard it is to control. My guess is that you do not have enough anode area or it is passivating. High speed requires extreme agitation, how is yours? James Watts
Third of four simultaneous responses -- June 8, 2006 Hi Kurt, Mark Baker
Fourth of four simultaneous responses -- June 7, 2006 I'll bet you have more than 600 ppm ammonia. Ammonia causes brittleness and is caused by, high anode current density, low pH, high current density, high temperature and 140 is worse 5than 120 F, and sulfamic acid that contains ammonia to start with. Do a distillation on the incoming sulfamic acid. It is very difficult to find ammponia free sulfamic acid on the open commercial market. Also, your chloride is too high.
First of two simultaneous responses -- June 8, 2006 The decomposition product of sulfamic acid are sulfuric acid and
ammonia. Hamilton Solidum
Second of two simultaneous responses -- June 9, 2006 I thank everyone for their responses. All my research has
indicated that ammonia causes stress in the plate, is this correct?
Unless I have my chemistry wrong, the sulfamate breaks down into
nickel sulfate and ammonium sulfate. Would not high sulfate be an
indicator of high ammonia? Kurt Sammons
First of three simultaneous responses -- June 9, 2006 pH 3.6 - 4.0, Temperature 105F, 1.5 oz/gal nickel bromide, no chloride.
Second of three simultaneous responses -- June 9, 2006 S-Rounds are far better for sulfamate than rolled depolarized because they dissolve with less current and hence make less ammonia. Your pH is too low, low pH makes ammonia,let it rise to 4.0 and hold 3.9 to 4.2. High temp also makes ammonia, try to run at 120 F. High anode current density makes ammonia.
Third of three simultaneous responses -- June 10, 2006 I have studied it but never ran a high speed sulfamate bath, only conventional and brush. Also, you already have too good and educated answers. But in my opinion you should have your defective plated wire analyzed by a well equiped and professional lab, not just the bath. There are too many things that can go wrong and raise the stress, from operating conditions to draged-in or by-product substances. Fortunately, most will leave a track to follow in the plate. Good luck. Guillermo Marrufo
Dear Reader: please choose what you want to do--
Save
