Letter 41016
Gold electroless plating
Hi,
I recently was suggested to use the OTOTEMP RTU gold electroless plating solution to deposit 10 um of gold layer on to a gold substrate,
may I ask the standard operating procedure for this, since I am not used to electroless plating (only electroplated copper once). I know that the reducing ions is in the solution, is this correct? Do we need to use external potential etc? What about the electrodes?
Does anyone has any info on this, thanks.
Amani Salim
Purdue University - West Lafayette, IN, USA
No power source or electrodes are required for electroless plating because, indeed, the reducing agent is in the solution. The manufacturer of the electroless gold plating solution will give you a technical data sheet which contains the recommended operating conditions, and it concerns me if someone has given you access to specialized chemicals without providing the MSDS and technical data sheet. Good luck.
finishing.com
Brick, New Jersey
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
List of Directories
