Letter 40093
Haze in Chrome LCD areas
Hello all:
I appreciate any help given....
I am having a problem with my chrome giving off a haze in
the LCD areas.
It is a standard Hex bath with no additives
33 oz chromic acid
.33 sulfuric
Water
Fume blanket
Chrome plating is preceded by standard bright watts
nickel.
I have tried varying the temp from 110 to 120 and get the
same results.
When I turn up the power to the point of making the haze
dissapear I start to get a slight burning on the
edges.
It does not matter the base metal as it happens with
everything from steel to zinc die castings.
I have sent samples out of both the nickel and chrome and am
awaiting analysis.
Tom Haltmeyer
hobby plating - Peoria, Arizona
Tom, sorry I can't be of any help with your question, but the
texture on the part shown in the photo is interesting, did you make
the part?
Duck
Lawrence Duckworth
- Cleveland, Georgia, USA
Lawrence:
The parts are from a early 1900s KOKER barber chair.
They are the "legs" that go from the arms down to the footplate.
Tom Haltmeyer
Just a shot in the dark but have you checked for any zinc
contamination in your chrome AND nickel bath in ppm?
Gary Joseph
- Johannesburg, South Africa
I have had High Iron in my chrome bath lower my effency of my
chrome bath. and cause the same problem, One source or either zn, cu,
or fe could be parts in the bottom of your tank.
Chris Snyder
- Charlotte, NC
Hello,
It looks like you have some passive nickel or your chrome bath
doesn't activate enough. Try a mixed catalyst bath.
Rudolf Kempgf
- Haan, Germany
I finally got it all fixed. :)
My leveler was very low in one bath and gone in the other in my
nickel. I has also learned that I should use a ratio of 5:1
brightner/leveler when making adds to the nickel bath. (I use a lot
of aux. anodes for restoration work and it was killing my
leveler)
I also needed more current in the chrome.
So......all is well now
Tom Haltmeyer
- Peoria, AZ, USA
Ed. note: Threads about barber chairs include Letters
7610,
15234,
15607,
24359,
26677,
40093.
