(Banner at right cycles thru suppliers of electroless nickel plating services) |
Letter 40090 Thick Ni-P layer [Taiwan]March 28, 2006 I am looking for some info about thick Ni-P (P wt.%
>11%). Becker Chian
March 30, 2006 Pinhole free high phosphorus type EN
coatings are possible, but require that the substrate also be free of
defects (like pores and inclusions) that will initiate pinholes or
other coating defects.
March 31, 2006 As properly stated by Mr. Duncan pin holes generally come from existing superficial defects. Also, from gas bubbles that adhere to the plated surface (then they look bottom-rounded and bright), from solid particles in the bath due to improper filtration, poor chemistry or poor processing practices. In general, if the corrective measures are not taken, the same results may be expected from an electrolytic NiP process. Guillermo Marrufo
Dear Reader: please choose what you want to do--
Save
