Need a salt spray testing service, or a salt spray cabinet of your own?
Look here -->
(Cycles thru suppliers)
Letter 40068
How to judge whether plating passes B117 12 hours or 96 hours? [China]
March 28, 2006
Many times I saw clear zinc plating can pass B-117 [link is to spec at TechStreet] 12 hours and yellow zinc plating can pass B117 96 hours. According to B-633 [link is to spec at TechStreet], it does.
but I have question, what does B117 12 hours or B117 96 hours mean since B117 is just a test method and doesn't specify the rusting degree (the rusting degree specified by D610 [link is to spec at TechStreet] ) ?
I just want to know at how much rust area is allowed to pass B117 12 hours test ? Can you guys please tell me?
thanks,
John
Nabob - ShenZhen, China
April 1, 2006
No rust is permitted.
Corrosion resistance requirements are given in ASTM B633 "Standard Specification for Electrodeposited Coatings of Zinc on Iron and Steel." After salt spray, Types II & III coated specimens "shall show neither corrosion products of zinc nor basis metal...visible to the unaided eye at normal reading distance" except white corrosion at edges.
Ken Vlach
- Goleta, California
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
