Letter 40055
Brass plating on hinges [India]
March 26, 2006
We are manufacturers of steel piano hinges and curtain pipes which are up to 12 feet long we want to do brass plating on it. Kindly inform us the most economical way of doing instead of doing nickel first and then doing brass or to apply copper first and then doing brass plating Or finishing the hinges first and applying directly brass on it to get optimum finish and which is as per European standards also.
ASHUTOSH
PIANO HINGES - JALANDHAR CITY, PUNJAB, INDIA
March 27, 2006
If you are looking for a dull, matte look, then plating brass directly on the steel hinges is fine. But if you want a bright look, plating first with nickel (or white bronze) and then with brass is the "standard" approach and probably the most economical because brass does not "level" enough to be brightly reflective directly on unbuffed steel.
An alternative would be nickel plating followed by a brass tinted electrophoretic lacquer, and this would eliminate the need for cyanide in the process. This has been done on a lot of "brass" lamps, but I don't personally know whether it will work with hinges; electrophoretic lacquer coatings are very thin, so there may be no bridging between moving parts but I don't know for sure.
finishing.com Inc. - Brick, NJ
April 30, 2006
THANKS FOR YOUR INFORMATION REGARDING BRASS PLATING. CAN I GET THE SAME YELLOW FINISH BY ZINC YELLOW PASSIVATION. AS THIS IS MOST ECONOMICAL.
ASHUTOSH
May 1, 2006
They certainly can be zinc plated and yellow chromated, and a person who is not sophisticated in metal finishing may not object; but even the best yellow chromate doesn't really look much like brass to someone who is looking for luster. Letter 4206 addressed this same issue.
One issue I have as operator of this site is that in trying to help the thousands of homeowners and consumers who submit maintenance questions about metal finishes, they often don't know what a finish really is these days. I realize that "piano hinges" aren't used exclusively on pianos, but if an owner rubs the chromate off the hinges on their new piano by using brass polish, who is responsible? If you used yellow chromate to try to make the hinges look like brass, I think you are. Good luck.
August 1, 2006
You can achieve brass colour with out nickel or with less nickel (like wood nickel which is plate direct on stainless steel and after the wood ni you can plate brass)
Vikas Shrama
- Gurgaon, Haryana, India
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
