HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 40049
Remove cement from ceramic tile
Post-hurricane Wilma I finally found a contractor to replace my painted shadow box fence. Not only has he disappeared without finishing the job, but a fine layer of cement dust was spilled on my tiled patio, it rained and now it has set. Is there any way to remove a thin coating of cement from glazed outdoor ceramic tile? Will pressure cleaning possibly get it off? Or acid? Any suggestions greatly appreciated.
Mary Hendersonhobbyist - Boca Raton, Florida, USA
Cement is nowhere near as hard as ceramic tile. Pick a small area and scrub it with a tampico brush, or a sponge with scotchbrite on one side, and come up with a practical scrubbing protocol for the whole patio. The sooner the better; cement takes at least a couple to a few days to fully cure.
You can do a couple of things. First, you can purchase a Phosphoric Acid Cleaner [linked by editor to product info at Amazon] for masonry/mortar clean up, or second, make a mix of 10% hydrochloric acid with water and spray or sponge over affected surface. Clean with fresh water. This will dissolve the film. Good luck.
Barry Feinman Restore It Yourself, Inc Carlsbad, California |
Hi use surclean or vinegar, and a lot of elbow grease! go easy on the stronger acids, they will also take off tile glazings, patterns etc. have fun.
Chris Foltz- Middle River, Maryland, USA
August 18, 2008
hey there chris.........
I'd like to thank u for your advice..... I used vinegar on the cement coating.... left it there for an hour or so.... after that, I scrubbed it hard with a regular utensil-scrubber.... and YES it actually worked! that small area where I applied the vinegar is now completely clean! I used regular cooking vinegar for the purpose.....
- Mumbai, India.
October 8, 2008
I have just had ceramic tile flooring removed and replaced with wood. There is quite a dense coating of cement dust left on my cloth and wooden furnishings - what is the safest way to remove it without damaging especially the wood?
Jackie Gentile- Hernando, Florida, USA
July 1, 2009
Thank you very much I followed the HCl tip and it worked great. You spared me a lot of money, I was going to change ceramics of my bathroom, I changed my mind after the stunning cleaning effect of HCl on the ceramics
Gihan Taha- Cairo, Egypt
July 1, 2009
Hi, Gihan. Congratulations on your success. But other readers must be warned that HCl can be a real problem if you don't watch what you are doing. HCl is not actually a liquid, it's a gas that is dissolved in water. As you slosh it around, the gas drifts away and attacks chrome, stainless steel, and electrical wiring.
Besides the need for personnel protection equipment, you need great ventilation and great care to not ruin things.
