finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 40040
pH of rust
My question is exactly complicated to search for so I'm asking this website to respond. I need to know the pH of rust to explain the process of corrosion
Zi H
fourth grade GT science - Cockeysville, Maryland, United States of America
First of two simultaneous responses -- ++++++
You might be having a problem finding information, Zi, because I don't think rust has a pH, the corrosive agent that is causing the rust will. If you put a piece of metal in some water and it rusts, you might want to find out what the pH of the water is. You can buy test strips to check pH.
I'm still amazed at how popular this rusting experiment is!
Sheldon Taylor
   supply chain electronics
Wake Forest, North Carolina
Second of two simultaneous responses -- ++++++
You've got it backward - the rust is the corrosion product, not the thing that causes corrosion.
I think that there is a FAQ that you can get to from the homepage that explains how corrosion works - it should answer a lot of your questions.
Jim Gorsich
Accurate Anodizing Inc.
Compton, California, USA
Rust consists of different iron hydroxides and oxides according to the conditions in which it formed. Also, the outer, middle and inner (next to the metal) layers of the rust will differ. Find "Characterization of rust on ancient Indian iron" on the Internet.
Measure the pH value of your rusted metal using pH paper (from teacher or a swimming pool supplier). Rinse the surface with the purest water available (distilled or de-ionized) and leave wet. Lay a strip of pH paper on the wet rust and wait for it to change color. This will give the pH of the rust surface.
Also, find "Solubility Equilibria" by DM Sherman, University of Bristol. It describes the solubility of alpha-FeOOH (mineral name: geothite) in water. From the diagram on page 10, FeOOH and Fe(OH)3 co-exist in water over a pH range of about 6.5 to 9.
Ken Vlach
- Goleta, California
