HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 40028
Difference between two plating notes for RoHS compliance
Hello,
Can anybody let me know what is the significant difference betwee these two notes listed below for Rohs compliance.
1. Underplate with 5 micron minimum Nickel. Plate with 10-15 micron matte tin to BS-6137 [link is to spec at TechStreet]
2. Matte Tin plate per ASTM
B545 [link is to spec at TechStreet], class "A" over Sulfamate Nickel per AMS-QQ-N-290 [link is to spec at TechStreet], 0.0001inches, minimum.
Thank You.
control aolutions - Bangalore, Karnataka, INDIA
The second^firstspec sounds twice as thick, Chandrashekar. But one cannot really plate in accord with a spec that one does not have. Acquiring them is probably step 1, and see if they clarify the issue. Good luck.
