finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 40020
How to do "oil rubbed" finish / blackened finish on a beaten copper sink?
How do I put an "oil rubbed" finish or blackened bronze finish on a beaten copper sink?
JESSE TAYLOR
HOBBYIST - BIRMINGHAM, Alabama
Hi, Jesse.
The easiest way to apply a patina is simply to brush on a patinating solution. You can find at this link on ebay, and some may be the tone you seek.
Real oil rubbed bronze is achieved by applying a brown oxidizing solution to copper, then buffing away the patina from the corners and wear points, bringing back the copper look there. A "living" finish will continue to wear to brightness at high points and darken where there is no handling, but most people seem to prefer to clear coat the item when it looks the way they want it to. More about how to do oil rubbed bronze can be found on letter 34482. Achieving the burnished look, with wear points a lighter tone and recessed areas a darker tone, may take some skill and practice. Good luck!
finishing.com
Brick, New Jersey
Jesse, I am a little confused. Which is it? You can do one or the other. "oil rubbed" is usually brown to dark brown while "blackened" is just that. My company can provide you the answer to either one in the form of chemical patinas or solvent dyes. Please contact me for more information. See our link below..
Barry Feinman
Restore It Yourself, Inc
Carlsbad, California
I'm trying to achieve an oil rubbed look on black flat painted hardware for kitchen cabinets that were originally brass looking with porcelain center pieces. Now they look too new and I'm trying to get that distressed age look.Any suggestions and do they need to be sealed with a flat polyurethane also to not have a shiny appearance. Thank you, Becky
Becky Fielden
- Maryville, Tennessee
Real oil rubbed bronze is achieved by copper plating, then applying a brown patina, then buffing away the patina from the corners and wear points, bringing back the copper look there, Becky. If you are starting with black paint, you can't actually patina it. However, you can apply decorative copper paint, and achieve the burnished look, with wear points a lighter tone and recessed areas a darker tone, by repainting everything but the wear points black. It may take some skill and practice. Once you have close to the look you seek, a polyurethane "matte" topcoat is probably a good idea. Good luck.
finishing.com
Brick, New Jersey
November 26, 2011
I made a kitchen table with legs and stretchers out of 1" dia. copper pipe. Is there an oil type finish I can put on matte finished / brushed copper?
I don't want a hard finish and I want to be able to easily touch it up. A little uneven wear pattern is OK.
Becky
Becky Davis
- Carmel, California
November 28, 2011
Hi, Becky.
Oil rubbed bronze is a "living" finish that meets your requirement. If you want to preserve a bright appearance instead, you could try sodium benzotriazole which is a copper preservative. Good luck.
finishing.com
Brick, New Jersey
