HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 40007
Seeking Plating Shop to electroplate a sculpture
I need a plating shop (in Leeds, England) that would be willing to plate onto a sculpture and also advise in what would be the best material for creating the sculpture in, in order to get the best finish from the copper plating.
Victoria R [last name deleted for privacy by Editor]Sculptor - Leeds, West Yorkshire, England
^- Sorry! This RFQ is outdated -^
August 31, 2008
Hi, Victoria. Hopefully a supporting advertiser contacted you in private to offer their services. Metal is easily the best substrate for plating onto, but just about any substrate can be plated -- although the durability may be a problem, especially if the sculpture is outside. For something unique, you could consider plating onto wax, then melting the wax away for a hollow sculpture (maybe you've seen hollow gold earrings?) But I would not pick a substrate (other than metal) until you've located a shop that can work with it. You might be interested in our FAQ about "Plating on nonconductive materials". Good luck! Regards,
