Letter 40005
Trevor Crichton |
Hi everyone ! I need your help badly. I need your professional
advise.
First of all, I would like to thank Mr. James Watts because of his
precious suggestion.
I work in compact disc manufacturing.
I am handling the process of stamper making (Nickel electroforming
If I wish to know the status of my bath's solution, what should I do
Laboratory tests can help ?
Here are my question :
( 1 ) If I send the solution for laboratory test,What the metals
should be tested ?
What is the specification for those tested metals ?
( 2 ) What are the metals or components suppose in Bath's solution
for stamper making ?
( 3 ) What are the metals suppose not in Bath's solution ? and how to
take them away ?
( 4 ) What is the definition for a good Bath's solution ?
I appreciate your kindness here.
Alfred Low
Electronic Manufacturing - Singapore
There is also an other possibility which can causes a bad smell
from the electrolytic solution :
decomposition of nickel sulfamate ion after that it gives
ammonia.
this reaction of decomposition is a result of working with high
temperature (more than 60°C)and lower PH (lower than 3.9).
check again temperature it should be lower than 60 °¨C , PH
,cooling system.
check also : boric acid concentration in the bath it should be 50
g/liter.
M O H A M E D B E N A M E
R
- ORAN ALGERIA
Anyone please give me your kindness help.
I need the answers for those questions stated above.
Alfred Low
Electronics Manufacturing - Singapore
Don't you think you should be asking your solution/additive supplier the questions people have already tried to answer for you in this forum?
John Martin
- Wales
I have tried few ways to solve my problems, but I can't get the
solution yet. My suppliers also can't help me in this matter. So, I
wish to get the solution from this forum.
My workers also complaint about this situation.
Alfred Low
As usual, we are trying to help with only a sketchy idea of the
problem.
One problem is that some people will barely notice a smell that
others find intolerable.
Hydrogen sulphide and ammonia have been suggested but don't seem to
satisfy our enquirer. Presumably he can tell the difference but 'a
bad smell' does not help much.
A fairly commom cause of smells (phenolic) in a plating shop is
breakdown of insulation in a rectifier. This is usually followed by
loss of current or a fire - so check!!
Failing this I would fit some fume extraction.
Perhaps you should also look if there is a dead rat under the tank.
Geoff Smith |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
