HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 39089
Joining Polypropylene Sheet
Hi,
I operate a wind tunnel in New Zealand, We have just relaid our moat(which is our water coolant supply for a 950 HP Detroit) the PP is 1 mm thick and if you could tell me how to join it together it would be much appreciated,we were given some Butyl double sided tape to use but it did not hold,
regards
bodyflying - Rotorua, New Zealand
First of two simultaneous responses -- ++++++ Hi Ron, |
| Freeman Newton - White Rock, British Columbia, Canada | Ed. note: Please keep Freeman in your thoughts & prayers. Message from Freeman, Dec. 2010 |
Second of two simultaneous responses -- ++++++
You have to hot weld it using parent rod of polypro and appropriate hot air guns (for very critical parts some recommend inert gas instead of air). Any good plastic fabricator can help you. Good luck.
The most effective method of joining polypropylene sheet is to weld it. Do a search on plastic or polypropylene welding for more info. John Martin- Wales Second of two simultaneous responses -- ++++++ Hi Guillermo,
++++++ Thanks to the two reply's , you have both been a lot of help ,I have got onto a company that think they should be able to weld it. - Rotorua , New Zealand |
Sorry friends,,but for materials that thin , you need an ultrasonic welder.. [I have one]
I have laramy - wegener - kamweld - liesters and god knows how many others...I've never seen a heat welder work on material .039 thick
Ron Landrette
plating equipment supplier - Bristol, Connecticut
Thanks, Ron. I know Ron, and Ron would know!
finishing.com
Brick, New Jersey
July 29, 2008
Dear,
by applying unimat tape with welding machine, U can joint your PP material with setting temp nobe.
Gajanan Mehta
- Dhari-India
