Caplugs
letter 39080
Need alternative to cyanide stripping of gold
We presently use a Cyanide bath to strip material of gold and would like to find an alternate method which is less dangerous.
Gene Artinius
- Manchester, New Hampshire
First of two simultaneous responses -- ++++++
Hi Gene,
I have tried to use non-cyanide gold strippers in the past, with poor results. They had to be heated to a high temperature, and took forever to strip the gold. It was a good thing I got the chemicals in on trial basis. You may want to call some precious metal suppliers (for electroplating), or a reputable refiner may know of a good product they currently use. Hope you find something.
Mark Baker
fellow plater - Syracuse, New York
Second of two simultaneous responses -- ++++++
Slightly acidified gold chloride as electrolytic etching solution can be used (object=anode),or aqua regia solution(if electrolytic method is not possible).
- Zagreb, Croatia
Hello Goran,
Thanks for the input.
Gene Artinius
November 18, 2009
Hi..
you may try this..
40% NaOH added with 23% sodium metabisulfite..Use ultrasonic system..The gold will be removed..
Monggoluton
- Malaysia
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
