Letter 39079
Need Bright Aluminum Finish - Mirror Like
I am an artist who designed a decorative part that is water-jet
cut from 1" thick aluminum 6061-T6 stock. The part dimension is
approximately 4" X 3". I would like to finish the part in bright
using the most economical process. I've considered chrome plating,
bright dip anodizing, polishing and I'm unsure which is optimal. I'm
also open to changing from aluminum, if the overall cost will be
reduced. Your help is appreciated.
Howard Chang
ID Works - Atlanta, GA
There is rarely a cut-and-dried answer to such a question, but
polishing/buffing it yourself can give you a quite shiny finish and
should be less expensive than farming the project out for chrome
plating or bright dipping and anodizing.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
