HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 39055
Solder removal from gold coins
Can solder be removed from 150 year old gold US coins to return them to original condition?
Donald ClevelandHobbyist - Reno, NV, USA
I have 2 gold coins that my grandfather soldered cuff links onto. Any idea how to get the links and solder off the gold coins?
Beau Ellingsonstudent - Prescott Valley, Arizona
First of two simultaneous responses -- ++++++
I removed my gold coins from a clasp by holding a soldering gun to the clasp until the solder melted. Although some solder remained on the coins, the gold was not discolored or damaged. Still waiting for answers on removing the solder.
Donald Cleveland- Reno, NV, USA
Second of two simultaneous responses -- ++++++
I would soak them in hydrochloric acid
[muriatic acid [linked by editor to product info at Amazon]], heated to work faster. The acid will not touch the gold but will dissolve the lead and tin. You may have to soak it, rub it with a soft cloth after rinsing off with lots of water, and put it in acid again. repeat until all the solder is gone.
Frank Zahn
- Centennial, Colorado, USA
Ed. note: Thanks, Frank. Readers should note that hydrochloric acid is a hazardous material. I don't think it dissolves lead, but assuming the tin content of the solder is high enough, it probably works. -- Ted
You can use next solution:
acetic acid(conc.)...........24%
hydrogen peroxide(30%).....4%
water.................72%
0,2-0,3 mm/per hour
- Zagreb, Croatia
