Letter 39039
Chrome, Cad, Zinc or Nickel plating best
for Paper Machinery
We are a small company engineering and manufacturing narrow width
(1m to 2m wide)paper and non-woven (Fiberglas mat, polythene mats)
machinery. We are looking to reduce the costs of the machiney parts
by plating them, rather than cladding in stainless steel or
manufacturing them in solid stainless steel.
These parts consist of heavy framing, stretcher machanisms, brackets,
rolls and bearing housings etc.
The environment on a paper machine can be hot (up to 170F) and very
humid, where most parts are continuously wet with water/fiber at Ph
levels of 5.5 to 7.5.
We have read extensively the comparisons of zinc plated, zinc,
galvanised, nickel plated and cadmium but we are looking for anyone
who has experience with long term corrosion resistance with plated
parts on paper machines, or similar equipment.
Alan Nicol
machinery - Montreal, Quebec, Canada
Only nickel plated is OK on paper machines.
Jacques Colmadin
- Paris
I agree with the previous response but for parts already designed
from just a mechanical point of view not taking in consideration they
will be subsecuently plated, I would go for electroless, not
electroplated Nickel, for it gets inside corners, entrant angles,
recesses, deep holes, threads, etc. with uniform thickness. Best if
you can get low phosphorus electroless nickel.
Guillermo Marrufo
Monterrey, NL, Mexico
Beware of Electroless Nickel if it is under 25 microns!! Rusting
will start immediately for lower thicknesses.
A more durable coat than EN is to plate 20 microns of Tri-layer
Nickel followed by Hard Chrome of upto 8 microns.
Khozema
Vahanwala
Saify Ind
Bangalore, Karnataka, India
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
