Need a salt spray testing service, or a salt spray cabinet of your own?
Look here -->
(Cycles thru suppliers)
Letter 39033
Inspection of ZAMAK coated with Ni/Cr [Egypt]
January 17, 2006
Hi all,
We are planning to manufacture some ZAMAK parts with nickel chrome, the parts must have a good corrosion resistance and a lasting fine shiny looking also.So we really needs to know what tests do we have to do on the products to be sure that those 2 goals will be met?
Some people have suggested B-117 [link is to info about spec at TechStreet] or CASS tests,are those the right tests we need?If yes how can we do them?
Your respond would be greatly appreciated
Mansour T. Gaafar
Plastics Manufacturing - Cairo, Egypt
January 18, 2006
Hi,
You need to specify more information.
As there are various zamak alloys (#3, #5, #7 etc), and are they being rack plated or Barrel.
What is the end use, and any other specifications.
Sridhar Bushigampala
- Toronot, ON, Canada
January 21, 2006
Dear Sridhar,
Thanks for your response.
We are intending to use ZAMAK #3,and they are intended to be Barrel plated.
The end use is a cubic pivot part used for riveting the cover of water cycle suite in the toilet.
The kind of test we need is a test that we can frequently run in the factory.
Mansour T. Gaafar
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
