Letter 39014
Nickel plating of inner diameter
[Serbia]
January 12, 2006
I need to nickel plate inner cylindric surface, diameter 70 mm
depth 150 mm thicknes 0,300 mm in sulfamate nickel solution. But I do
not know what nickel anode would be appropiate? What is the optimum
distance between anode and the surface to be plated. What kind of
complications can appear in nickel plating of inner diameters. I
would appreciate any helpful information.
Vesna Jovanovic
airways - Belgrade, Serbia
First of two simultaneous responses -- January 13, 2006
Vesna,
The best way it to use a platina anode in protection with anode sheet
the anode can be 0,3 mm thats if enough. If you use a current density
approximaly 2A/dm2. With this the nickel layer willbe a little harder
but you save a lots of machine woorks.
Anders Sundman
surface finishing engineer
Sweden
Second of two simultaneous responses -- January 16, 2006
Dear Vesna!
the diameter is not important as long as the solution can circulate
and the nickel in your anode is enough to build up.
the important thing in sulohamate nickel is the adhision problem ,so
you need to apply aroun half to one volt before you immerse you part
,and keep that voltage fo couple minutes till the part get to bath
temp,after increase the amps slowly to around 40-70 or so amps per
foot.
good luck and God bless /hope this will help.
Cair Shishani
aircraft maintenance - Abu Dhabi, UAE
January 19, 2006
Thanks gentlemans,
I hope it will works.
Vesna Jovanovic
- Belgrade, Serbia
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
