finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 39010
Bonding polyurethane tread to a nylon 6/6 30% glass filled hub
Any suggestions on adhesives or surface preparation that would increase peel strength of bond between a polyurethane tread and a nylon 6/6 30% glass filled hub. The nylon is injection molded. The tread is poured around the hub and allowed to cure. Bond must be developed in process.
Thus far, have tried various thixon (403, 404) and chemlok (219) adhesive product with little success. Results point to incorrect adhesive or insuffcient surface prep.
Surface has been grit blasted, and the cleaned with hysol.
Any suggestions would be greatly appreciated.
Elmer Lee
Caster Concepts - Albion, Michigan
October 1, 2011
Try using a 2 component MS Polymer adhesive from either Bostik or Merz & Benteli
Noel Godson
- Sydney, Australia
