Letter 38074
Need a maskant to withstand 190F and 12ph
plating process
We need a maskant that will withstand 190F plating bath
temperature and 12 ph solution. we need to hold .020 tolerance and
are having trouble with our existing maskant not leaking when exposed
to these conditions. Any advise would be much appreciated.
Sincerely,
Patti Kientz
Plating company - Santa Ana, CA, USA
First of two simultaneous responses -- +++++
The quality of the response is proportional to the quality of the
question.
What you are currently using would be a nice place to start. What
else have you tried. What is the shape and finish of the part. Can
you use solvent to remove the mask?What other constraints can you
think of?
Second of two simultaneous responses -- +++++
Most maskants are photopositive materials and are designed to
operate at low pH and to be developed (or stripped) in high pH
solvents. What you need is exactly the opposite, namely a
photonegative photoresist that can be used at high pH and is
processed with low pH solvents. You can get some basic formulaations
from textbooks on the subject, but the intricacies of photoresists
are such that you will almost certainly need technical backup. It is
therefore better to ask a professional supply house for their
products. Try asking Kodak or one of the other photoresist suppliers
for further advice.
R&D practical scientist - UK
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
