Letter 38073
Effect of Impurities in Chromic Acid
Anodizing Solutions
We currently use a chromic acid anodizing process, and it has come
to our attention that we should be analyzing for sulfates as an
impurity. My question is, what effect does sulfates have on aluminum
and/or aluminum alloys in this process?
Jennifer Friesen
Chemical Technologist - Winnipeg, Canada
First of two simultaneous responses -- +++++
I have seen companies that did not test for sulfate. They bought
certified low sulfate chromic acid, used DI water in all tanks, did
not use any chemicals contaaining sulfate and rinsed well. The tank
will die from aluminum buildup before sulfates get to a level of
causing a problem.
One reason that sulfate is a problem is the chrome will plate out on
the cathodes.
Second of two simultaneous responses -- +++++
Sulfates cause the coating to be less opaque. Sulfates may come in
through grag-in if there are any upstream or as a common impurity in
commodity flake chromic acid. You may remove sulfates from the
anodizing solution with barium carbonate or barium hydroxide. One
part barium hydroxide removes 1/5 part Sulfate by weight. Graham
expresses it as,"One part Barium Hydroxide will remove 0.3 parts
SO4/weight". Boeing limits sulfates to 500 mg/L. All of the above
taken from "Aluminum How-To" by Robert H Probert, publication
pending.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
