Letter 38071
High Conductivity Acid Copper
Electroforming
I am interested in using acid copper electroforming to build high
power transformers. The designs are such that standard fabrication
techniques would be difficult. The plate must be very high
conductivity, on the order of 100% IACS and approximately 1mm thick.
As I understand it, standard acid copper formulations give a lower
conductivity (~75% IACS) plate due to the codeposition of impurities
from the brighteners, levelers, etc.
For this reason I am considering using an additive free high throw
bath consisting of 80g/L CuSO4-5H20, 200g/L H2SO4, 15-50ppm Cl @
~20A/sqft. I have read of pulse reverse being used in an additive
free bath to increase throwing power and also to control surface
roughness (leveling) while providing a deposit of 101% IACS for
particle accelerator components. The most important factor is
conductivity, I would guess that excessive surface roughness would
lead to voids/discontinuities forming in a thick layer like this. I
would appreciate any comments or thoughts on this bath chemistry and
the use of PR for this application. Any references that cover the
specifics of this type of process (no organics, high throw, acid
copper with PR) would be great.
I also have some simple questions about anodes, why are high
phosphorus anodes required? What is the reason why C110 (.04% O), or
oxygen free materials (C101/102) can not work? Will C122 work
(0.02%P)? I ask because of the high cost of C812 (0.04-0.06%P) anode
material. Also it seems reasonable that some of this phosphorus would
end up being co-deposited which would lower conductivity
dramatically. I have built some simple test plating cells that used
C110 as anode material for plating ~10mil layers DC, seemed to work
ok.
Thank you for your consideration.
Eric Prigge
Electrical Engineer - Huntington Beach, CA US
It would prove useful to do a literature search with 'Jack Dini'
as the author. Jack has published a number of papers on high tech
copper electroforming. Good luck.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a
different subject.
