Letter 38060
Electro-plating bismuth-aluminium-copper
alloy
I have a question.
I need to electro-plate bismuth, aluminium, copper on aluminium
foil/sheet. This is a experiment on technology you might not
understand.
aLSO, IN WHICH ACID CAN i DISSOLVE FINE POWDERS OF THE METALS
DESCRIBED ABOVE TO PRODUCE PLATING SOLUTION? I was told that i can
dissolve some metals in acid and then plate from that solution. But I
got a question on it that if dissolve the Bismuth for example and
then put in aluminium foil to plate bismuth on-will aluminium get
dissolved in that acid or the thin bismuth layer get dissolved as
soon as it get plated on?
Siarhei Borisov
Scientific Research - Newcastle Upon Tyne, United Kingdom
Siarhei, you need to go to a plating shop and have them assist you
with this project. I would not say that it is impossible to do what
you want to do, but the barriers are extremely imposing for a skilled
electroplater with decades of experience. To try to accomplish this
when you have no electroplating experience is not going to get you
anywhere. Some of the barriers: in general you can't plate onto
aluminum without a zincate pretreatment; in general you can't plate
aluminum or any aluminum alloy out of an aqueous solution; in
general, you can't make up plating solutions by dissolving metal in
acid; in general you don't make plating solutions, you buy them so
that you can take advantage of the decades of development effort that
preceded your experiment; in general it is difficult to plate binary
alloys and exceptionally difficult to plate ternary alloys because of
the Nernst equation. Visit a prototyping plating shop for your
project.
finishing.com
Brick, New Jersey
Siarhei, plating a bismuth-aluminium-copper alloy onto an
aluminium substrate is not an easy task. As Ted says, it is
impossible to electrodeposit aluminium or aluminium alloys from an
aqueous bath - it just doesn't work. However, there is an increased
interest in electroplating from "ionic liquids", where the problems
associated with aqueous technologies are not found. A couple of
British Universities are looking at the technology, so do an internet
search and find out more details about it. One of the possible
advantages of this technology may be that depositing onto aluminium
will not require the usual zincate treatment that Ted quite rightly
refers to as being essential for aqueous depostion onto aluminium.
Alloy deposition of this type of formulation will be very problematic
because of the wide ranging postions of the metals in the
electrochemical series, but with adequate complexing, it may be
possible.
R&D practical scientist - UK
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
