HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 38039
Testing for Copper Contamination in Ni electroplating baths
+++++I am the new chemist for an electroplating shop, and want to begin testing for copper contamination in my Ni baths. I want the test to show quantitative data, and am not really sure if there is already a procedure for this testing or if I need to design one myself.
Thanks for any help.
Egide USA, Inc. - Cambridge, Maryland
First of four simultaneous responses -- +++++
Generally people use AAS or ICP if available. You might get away with UV-VIS depending on your situation. What do you have available?
James Totter, CEF - Tallahassee, Florida |
Second of four simultaneous responses -- +++++
Analyze the bath for copper (ppm) with an AA or ICP. Otherwise the only other way is not quantative but by waiting until a dark lcd area appears on Hull Cell tests (1 amp/5 minute). The test panel can be misleading in that it would also show zinc contamination in a similar manner.
Gene Packman- Great Neck, NY
Third of four simultaneous responses -- +++++
Angela,
if you really must quantify it then you will need acess to a atomic absorption instrument (AAS). If you work for a smaller plating shop that cant afford this instrument then the best way is to check copper contamination though plating a hull cell and looking for darkness in the LCD regions (although this could also be caused by zinc) and this wont obviously give you any numerical values. Ask the supplier of the plating chemicals to test the copper levels for you. All decient suppliers should be able to do this.
- Melbourne, Vic, Australia
Fourth of four simultaneous responses -- +++++
You will need to do a few tests; firstly do Hull Cell tests to get the copper contaminated nickel deposit. Observe the characteristics of the deposit and then do EDAX analysis to determine the amount of copper present. You can teh correlate the amount of copper in the nickel to the visual characteristics as well as having a handle on how copper an nickel deposit relative to each other at different current densities. I suggest you use stainless steel panels, as normal Hull cell panels are brass and contain copper!
Trevor Crichton R&D practical scientist The Pheasantries - Chesham, U.K. |
