finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 38027
Name for dipping red hot steel in oil
What name is given to the process, where u heat the steel to a cherry red and then dip the heated object in engine oil. I have used this many times in the workshop, at university as it gives a black finish that does not corrode. I was just wondering if any one could tell me the technical name for this process as I am doing a project and need to name the above process.
Many Thanks
Robert, Wilson
Student - Portsmouth, Hampshire, England
First of two simultaneous responses -- +++++
Robert,
The name I'd use is VERGLUEHEN (VERGLÜHEN) ... Normally the 'U' is or has an umlaut, the twin dots over it instead of 'ue'.
It is an annealing process, is it not.
By the way, back in l922-ish, my grandfather, a naval architect, was responsible for upgrading the Victory and seeing that you are a Pompey-ite, I thought you'd be interested.
Freeman Newton - White Rock, British Columbia, Canada
Ed. note:
Please keep Freeman in your thoughts
& prayers.
Message from Freeman, Dec. 2010
Second of two simultaneous responses -- +++++
Quench is one name.
For steel, it is a hardening process. Annealing is holding the part at an appropriate temperature, like 400F, for a given period and letting the temperature coast down,
How about "oil quench".
R&D practical scientist The Pheasantries - Chesham, U.K.
It is called oil blackening and is often used when treating gun barrels to give the blueish look due to the type of oil used.
Jabulani Johnson
- Bristol
I think the process is called tempering.Tempering has two stages , Fistly the material is heated above a critical temperature then cooled rapidly (quenched) to freeze the material in a hardend state,Then the material is heated to a lower temperature to refine the grain structure to give hardness suitable for the job intended
jim conkey
- Perth Western Australia
December 11, 2008
http://en.wikipedia.org/wiki/Tempering
Kindly go through the above site for different type of heat treatment in metal
C.Manikandan
- Chennai, India
