Letter 38017
Copper plating cold rolled steel discs
I am interested in a large scale plating process of applying
copper onto cold rolled steel discs. The steel will be 0.050"
thick,with a diameter of 0.750". Copper plating should be about
0.0004". Can the copper be applied directly, or is a flash plate of
anything else required? How long would the discs need to be in
solution, I would guess a barrel plating line? How well will the
tokens hold up in use?
Jacob Katz
Private token manufacturer - Phila., PA, USA
The tokens could be cyanide copper plated, but it might be more
satisfactory to cyanide copper strike them, then bright acid copper
plate them. A barrel plating line would be ideal, but beware of two
wet tokens sticking together by capillary action, with no plating
between them. That would be less likely if the discs have features,
like a rim or embossed or raised writing, etc. The plating time can
be calculated, but until someone takes the time to do that, let's say
about 20 minutes. Pennies are copper plated zinc, and they hold up
well; no reason to suspect your tokens would fair more poorly. You
can research exactly how pennies are plated because technical
articles have been published on it.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
