HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 38004
PVD zinc plating process for fasteners?
+++++Hi,
I would like to know more about PVD plating process, which can be used for hydrogen embrittlement free Zinc coating for high strength steel fasteners.
Vasu
- Bangalore, Karnataka State, India
Costs too much to be competitive and is higher technology. Look into mechanical zinc plating.
If you use acid cleaners, you will still have an embrittlment issue.
We plated cadmium for years without a notch bar failure using very high strength notch bars. We blast cleaned, used a periodic reverse cleaner, rinsed, 15 seconds in the acid, rinsed,and plated. Bake was immediately after parts were dried. Cad is considered worse than zinc by most people for embrittlement.
