Letter 37098
How far do I have to oxidate the silver
layer? [Mexico]
Hello,
We have a small plant here, putting a layer of silver on decorative
parts (on Ni after Cu acid, Cu alc on zamac pieces).
We have a liquid oxidant to oxidize the silver (don´t know the
substances).
In the beginning we used 50% solucion and the pieces turned dark,
almost black.
We diluted the solucion and now the oxidant is at 15 vol % in water.
The oxidation process is slower. Problem is I don't know where to
stop it to have fine pieces at the end. We immerse the wet (just
washed) silver pieces and get the following process:
- First (after some sec.) the pieces turn like yellow-gold.
- Then (idem) they get a bright blue colour, but it is still not a
uniform colour.
- Then (idem) they turn a bit red, gray.
- Finally (idem) they get a dark blue and uniform colour.
I wonder at which colour I need to stop the oxidation process. Now we
stop at the end but it seems to me we are losing some of the bright
silver refexion (compared to other pieces from other
suppliers).
(Silver bath is new and checked by provider.)
(there is a post treatment, so the pieces won't oxidate
further.)
Marc Michiels
anonymous - Mexico
Since there are dozens of ways to oxidize silver, it would be
helpful if you could tell us which one you are using. But, in
general, simple dilution will not usually give you the desired
finish. There is usually an optimum concentration for a particular
antiqueing or aging, or oxidizing solution, and there is often more
than one component so dilution will throw off the reaction in ways
you won't be able to anticipate. For instance, if the original
solution contains 10 g/l sodium chloride, and 50 g/l of another
chemical, diluting to 50% may put the chloride ion at a level where
it does nothing, rather than the effect desired at 10 g/l.
I would try other oxidizing solutions, proprietary or not, and follow
the directions on the technical bulletin.
- Levittown, PA
What we do here is dipping the pieces that come out of the Ag-bath
(and after washing them) in a water (not distiled) solution with 10
to 30 vol% of the oxidizing liquid. We do not have the tecnical
bulletin of that oxidant and that is indeed a pitty (don't ask me
why).
You wrote : there are a dozen of ways. Maybe we need to try another
method here. Can you give us more information about the diferent ways
that exist to oxidize silver? How can I obtain more information about
that topic?
I want the silver pieces to have a slight blue, more or less bright
oxidation layer.
Marc Michiels
- Mexico
Since your "silver pieces" are plated with silver, the silver
blackening immersion time you would like know is related to your
silver plated thickness, its thickness is equivalent to the plating
time.
In order to keep the brightness of the silver pieces after
blackening, I think that by increasing a little more the plated
silver thickness and using undiluted blackening solution will help.
Heat up the blackening solution at 60 *C or keep the blackening time
as short as possible, you will have a brighter surface with a thicker
silver plated layer.
Yung-Han Kuo
- Omnoi, Samutsakorn, Thailand
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
