Letter 37085
Need 6061 T6 to retain as much heat as
possible
Ok heres the deal. I have to design a new oven for a costumers
oven. The machine runs 300 degrees C, 24 hours a day, 7 days a week.
The oven is inside a machine, I need it to retain as much heat as
possible. Will anodizing help or hinder my project?
Matt Spicer
- Fairfield, Ohio, USA
First of two simultaneous responses -- +++++
The anodize may crack if cycled to that temp. Decreasing
thermoconductivity of aluminum is a waste of effort unless it a very
unusual problem. Think insulation or vacuum or trapped air space.
Second of two simultaneous responses -- +++++
Essentially, if I can recall reading this correctly. In terms of
heat retention. Anodizing will insulate and retain more heat than a
non-anodized coating. My knowledge of such is in heatsinks and their
effects in PC applications. I know that in actuality an anodized
heatsink will extract heat at a slower rate than a non-anodized one.
So in reverse, in your application it would help.
To what extent, I can't tell you exactly. I can tell you in a PC
application, a 1-2C variance in a roughly 80W-100W processor is
noted. Thats minor in the real world, but its significant in certain
situations. If anodizing insulated and made a 10-12C differential,
I'd call it considerable.
My suggestion, take the thickness of the plate you were going to use,
cut em 12 x 12, anodize one, don't anodize the other. Put temp probes
that are capable of withstanding those kinds of temps on to the
parts, and heat them up. Pull them out and measure the differential
in temperature loss. (You can probably also achieve this at timed
intervals with one of those fancy laser light temp probes) Whichever
loses the heat faster, is going to be the lesser desired application
for you. Thats the only true way I can think of to test this theory.
You can take my, or anyone elses word but till you put the rubber to
the pavement so to speak, you can't validate anything.
Matthew Stiltner
plating company - Toledo, Ohio
The thermal coefficient of expansion of aluminum oxide is 0.2 that
of the raw aluminum. AT 300 C the raw aluminum will expand 5 X that
of the oxide and the oxide wilil fall off.
Hardcoat anodize is widely used on cookware and commercial pizza
pans for it's wear resistance and improved heat distribution. In
these applications, it is exposed to thousands of thermal cycles and
does not "fall" off.
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a
new question or inquiry on a
different subject.
