Letter 37082
Calculation of Cascade rinse water
consumption [Turkey]
We want to calculate rinse water consumption and flow rate for
alkaline zinc and silver passivation plating unit , plating tank 3
cub m , plating area /h =0,8 sqm /h
H.Yenigün
- Turkey
Unfortunately there are still two unknowns after you provide all
of the information that is available. The first is the dragout rate,
and it's virtually pointless to even attempt an estimate based solely
on surface area, as is explained in Kushner's
"Water and Waste Control for the
Plating Shop".
The second unknown is what contamination level in the final rinse
tank will prove satisfactory. Again, it's hard to say, and can depend
on other things, but the ratio 1000:1 is occasionally mentioned. In a
cascade rinse tank this can be achieved with 33 parts of water. (If
you dilute the dragout 33:1 in the first rinse, and dilute the
dragout from the first rinse by 33:1 in the second rinse, you've got
1000:1; and in a cascade rinse you use the same 33 parts of water in
both rinses). So, if you take a stab at the dragout rate, based on
shape and production rate, and multiply by 33 you will have a rough
(ROUGH!) estimate of rinse water requirements. Good luck!
finishing.com Inc. - Brick,
NJ
Sir: I have published 2 or 3 articles on rinsing and draining in
Metal Finishing that would be useful
to you. I know factually that in Hot Dip Galvanizing that for two
counter-current rinses and an off-line storage tank that 0.5% sulfate
is equilibrated in the flux solution from sulfuric acid pickle
containing 28% sulfate. Thus about each week all of the more
contaminated rinse (R1) is put into the off-line storage tank; the
cleaner second rinse (R2) is put into the now empty R1 tank and new
water is put into the now empty R2 tank. During the week, rinse water
in the storage tank is used up due to evaporation in the hot sulfuric
acid tanks (usually 3 acid tanks at 150F). Also the steel product is
dipped twice in each rinse tank to remove "adheared" acid adjacent to
the steel and to help remove "bridged" and "cupped" acid on the
product. This process is repeated again and again to equilibrium. My
articles explain this with drawings and diagrams.
Dr. Thomas H. Cook
- Hot Springs, SD
Ed. note: One of Dr. Cook's articles is referenced in our
on-line article "20 Ways to Reduce
Water Usage in Plating Shops".
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
