Letter 37077
Powder paint removal without ruining
spring temper?
How do you remove powder paint from a spring loaded metal clamp
and not degrade the spring? We use a pony #3201 metal clamp which has
a metal spring for tension, to hold parts to our rack. After a
multitue of coatings the clamp hinges are imobilized. Heat sufficient
to remove the paint degrades the spring tension and makes the clamp
useless. Freezing make the paint chip easier however it warms up
fast. I am going to try a hot water bath. Thanks.
Patrick Andres
Cardinal Aluminum Co. - Louisville, KY
Avoiding a process that you have to use the word "hot" to describe
is your best bet, but in a molten sand bed the parts only have to be
in an hour or so, it's possible that you wouldn't have to worry about
the spring annealing in that amount of time. Then there is chemical
stripping, sand(or some other media) blasting, cost analysis to see
if it's more economical to replace them than clean them, wrap high
temp masking tape around the area where the spring is so you can use
them longer before they need to be stripped....?
Sheldon Taylor
supply chain electronics
Wake Forest, No. Carolina
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
