Letter 37060
What contamination causes yellowish tone
for plating with zinc chloride in Hull Cell?
[Taiwan]
Dear Sir/Madam,
When using HULL CELL plating test for zinc chloride, it usually
presents white homogeneous tonality but this time prensents yellowish
tonality which is more evident specially when the product to light as
some yellow dots to appear and give this color showing a lack of
deposit and penetration in the current low density zone, before that,
we have a uniform deposit in all current areas and do not present
this coating failing.
Our plating formula is as follows: zinc chloride 65gr/Lt, Boric Acid
25 gr/Lt, Carrier 4.0%, Brightener 0.02%, 5 min, 2 amp,AA. Can you
tell me what caused it? what kind pollution is this? Many thanks for
your attention and looking forward to your commends.
B.regards,
Robert Lim
Plating chemicals manufacturer - Taiwan
Hello,
I think your bath is contaminated with iron , which turns your
solution colour to yellowish, hydrogen peroxide treatment , followed
by carbon , then filteration of solution will make your solution
clear after removal of iron.
Praven Kumar
- Mumbai
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
