Letter 37056
Nickel peeling problem
We are barrel plating millions of very small metal pieces monthly.
The same semibright nickel baths are also used for coating larger
components. Our problem is that occasionally the very outmost nickel
layer is peeling of in tape test. Also in microscope studies we can
see strong layering and sometimes even cracks parallel to the
substrate. It looks like the problem only exists in plating specific
shapes. The adhesion to the substrate is good though.
Does anybody know why this kind of phenomena can be seen? Inner
stresses? Current cuts and passivation? Organic impurities? Barrel
movement? Something else?
Please give me an idea how to proceed here. I am beginning to feel a
little bit stupid.
Vesa Kankare
plating shop - Finland
You need to give more details. Pretreatment details, plating
chemistry and parameters, type of arrangement and equipment used
(barrel only or hang of larger parts).
Guillermo Marrufo
Monterrey, NL, Mexico
Firstly, what kind of material is it? pretreatment, activation of
substrate is very important, but is not all.
How are obtained the pieces. Also this depends a lot.
Dan L. Rujan
- Arad, Romania
If appears you have nickel from nickel flaking. Sometimes the
problem is easily fixed, sometimes it requires more investigative
procedures. It appears the flaking is caused by something going wrong
in the nickel bath. First thing look for something that has changed.
I suspect a bipolar electrical condition, make-break contacts,
overloaded barrels, defective conductors or buss rails, and don't
forget to inspect the danglers inside the barrels.
Larry Brannock
- Cana, Virginia
Hi Vesa,
I think your barrel loses contact. So you must serve the connection
in your barrel.
Anders Sundman
surface finishing engineer
Sweden
April 8, 2009
Please concentrate on Barrel's motor speed, Activation of the
parts, anti pit concentration, organic contamination, excess of
brighteners/additives.
Shafiuddin A. Mohammed
metal coating
shop
- Dubai, UAE
