Letter 37055
Can anyone suggest a coating or plating
for this application? [Pennsylvania]
APPLICATION:
Various thermoplatics (e.g. PE,PP,PS) will be melted in A 4130 DOM
steel
tube and then a 304 stainless steel piston will be pressed into the
tube
to extrude the melted plastics from the tube (via a nozzle
orifice
press-fitted into one end of the tube).
PARAMETERS:
Temperature range of tube: 300-650 F
Temperature range of piston: 100-550 F
Size of stainless piston: 8"L x .625"Diameter
Size of steel tube: 5"L x .63 ID (nominal)
OBJECTIVE:
1)To minimize potential sticking of the thermoplastics to the
piston and the tube.
2)Low COF
3)Helps protect surfaces from corrosion and rust.
PREFERENCE (not critical): colorless coating for the stainless
rod
Thanks in advance for any responses.
Jay Braun
R&D - Allentown, PA, USA
I would prefer electroless nickel with teflon particles, TiN or
thin dense chrome. All are very effective but none is cheap or easy
to find.
Guillermo Marrufo
Monterrey, NL, Mexico
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
