(Cycles thru suppliers)
Letter 37051
Rinsing after stainless steel passivation [Mexico]
What are the minimum requirements of water (pH, hardness, conductivity, etc.) to wash stainless steel after performing any manufacturing process and for passivation purposes?
Sergio Ortiz
filtration - Monterrey, Nuevo Leon, Mexico
Your question is quite broad to be answered in a couple lines, but you are right to be concerned on this matters. Water quality can directly affect the quality of products. The water quality will depend a lot on the application (medical, aerospace, semiconductor, etc).
In the case of citric/nitric passivation, according ASTM A-967 [link is to spec at TechStreet] final rinse water should not exceed total dissolved solids of 200 ppm. I even believe this is too much. I think softened and 10 micron filtered water is ok for general purposes. R.O. is preferred. pH of rinse water must also be controlled to a "neutral" range to avoid product carrying acid residue to the customer.
If the application is critical, such as semiconductor industry, ultrapure deionized (DI) water is a must, as well as monitoring purity of parts. So you can see the application must be considered to know what water class is needed.
Manuel Sández
High purity Components Manufacturing - Hermosillo, Sonora, Mexico
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
