Caplugs
Letter 37050
Principle of Chemical Polishing
Please share the principle of chemical polishing.The common chemicals used : mixture of conc. H3PO4 / HNO3 / H2SO4 with high temp. of 90 degC.
Can the mixture of diluted H3PO4 and HNO3 with ambient temperature to be used as chemical polishing process ?
Is there any difference in surface finishing for above both process ?
Thanks for sharing the info.
T H Neo
plating shop - JB, Malaysia, Malaysia
This is the third subject you've asked for help on but you haven't yet taken the time to reply to anyone else's questions. Share and share alike, Mr. Neo :-)
It's not clear what you mean by chemical polishing. I think you mean chemical polishing of aluminum? Or do you mean stainless steel? Please describe your own situation rather than framing your question in such an abstract fashion. Thanks!
finishing.com
Brick, New Jersey
Sorry for not specify the material involved. Refer to applied chemical polishing on Al 6061 alloy. Is it the chemical polishing only operated in 90-100 degC condition ?
T H Neo
- JB, Malaysia
Closer to 100 degrees than 90 degrees. See letter 30736 for more info.
Ted Mooney
finishing.com
Brick, New Jersey
Hi Ted,
Thanks for your reply.
T H Neo
- JB , Malaysia
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
List of Directories
