Letter 37045
Reliability of silver contacts in relay
pressure switch
Hi, I am trying to figure out whether silver contacts are reliable
enough over time for a relay switch we're using or we need to use
gold contacts. The switch is going to be used in a 5V circuit as
logic control and will bear ~10mA load when it's on. Since the switch
serves a failsafe purpose it will be pretty much always off unless
something goes wrong (over pressure in the system). The trigger point
of the pressure switch is about 6psi and the device is a medical
device that will be used in controlled environments such as hospitals
or physicians office. We are aiming for a 7 year lifetime for the
device (and thus the switch).
I've read that silver tarnishes over time especially at low currents,
or when switching action is absent. but I've always read that there
needs to be sulphur in the environment for silver oxidation to occur,
and that silver oxide is also conductive.
anyone has opinions on whether silver contacts could stay reliable
for 7 years in a controlled environment in this application?
thanks much,
Ethan Kung
VSM MedTech - Coquitlam, BC, Canada
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
