Letter 37008
Passivating/Pickling
After Tig welding stainless steel tubing, we then go through the
process of pickling/ passavating the heat spots. This is done in the
usual manner using acid cleaning and then scrubbing off with scourer
pads. My question is that does anyone know of a quicker or easier way
to remove the weld heat marks off the stainless.
John Kernan
Stainless steel manufacturing - Brisbane, Qld, Australia
The last couple of times we printed similar inquiries, we were
inundated with responses that were ads for proprietary pickling
pastes and electrolytic stain removal machines, John. So we suggest
that you try those terms with a search engine. We will print any
TECHNICAL responses we get, but we can't print ads or testimonials or
patent numbers. Good luck.
finishing.com
Brick, New Jersey
John
I am not sure where to find documentation, but I know some shops use
a heated potassium permanganate solution, followed by a nitric acid
dip to remove the weld scale. It is somewhat time consuming, but not
labor intensive. The scale comes off faster if it is brushed
immediately after welding.
Willie Alexander
- Colorado Springs CO
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
