Letter 36096
Diffusion Treatment Of 316 Stainless
Steel
My company is trying to identify a process used to modify the
mechanical properties of 316 stainless steel. 316 is used for the
control element in metal-seated gate and ball valves. We have seen
samples of 316 valve components that have been manufactured using a
process that produces a hard Rc70+ surface finish that doesn't affect
the corrosion properties of 316. The process is claimed to add
lubricity, resists galling, and can be done to finished components
without distorting or changing the dimensional tolerances on the
components. We understand this process can be used on any ferritic
material. Treated components have a black, semi-gloss
appearance.
Can anyone help us identify this finishing process so we can have
some test pieces done to see if we can achieve these goals?
Sheldon Jaffe
Valve Distributor - Vancouver, BC, Canada
Sounds to me like salt bath nitriding, or possibly a cryogenic
treatment or ion implantation. The nitriding sounds most likely.
finishing.com
Brick, New Jersey
We all could get a better idea if you told us how thick is the
coating you're looking for (or after). Nitriding matches your
described color but its main disadvantage is that it reduces the
corrosion resistance of SS. So, it may very well be something else.
Guillermo Marrufo
Monterrey, NL, Mexico
We're told the process provides a treated depth of 0.020 to
0.030". Our application is for the blades (gates) in knife gate
valves used in mining and pulp mill applications. We use 316 plate
for the gates, but run into problems in line media that is sticky or
contains abrasive particles. We've tried Xylan (Teflon) coating the
gates, which solves the sticking issue, but doesn't provide any
protection against abrasion. We've tried are making the gates out of
T15 tool steel, but they don't handles corrosive fluids well. 17-4PH
stands up well against the abrasion, but it's chemical resistance is
poor compared to 316 and it's quite expensive. Another option we've
tried is applying a Stellite weld overlay to the gate leading edges,
requiring considerable machining to get consistent finished sizes and
is unpredictable when our process temperatures vary - the gates warp
and will no longer shut-off properly.
Bottom line is we've been told a process like nitriding will do what
we want, but we don't want to spend a huge amount of money trying 382
different process before we find one that works. What we are looking
for is a company who can suggest some methods to achieve what we're
looking for - narrow it down to 6 to 12 potential finishing systems
so we can run tests to see how close we can get to our ideal product.
Sheldon Jaffe
- Surrey, B.C., Canada
20 to 30 thousands sound within modern HVOF range capabilities.
Nitriding will not penetrate that far w/o loosing its hardness.
Besides, it wouldn't do any good to the overall corrosion resistance
of 316SS. Another option could be composite nickel or cobalt
electroplating with SiC or other hard stuff. Both processes are low
temp, highly technical and expensive, and will require smoothing out
the surface.
Guillermo Marrufo
Electroless nickel, heat treated after plating, will provide a
hard and corrosion resistant surface, and may do what you need done.
.030" is probably not practical, but may well serve the purpose a few
mils thick.
Jeffrey Holmes,
CEF
- Spartanburg, SC, USA
For your application you can go for salt bath nitriding and
followed by oxidizing process.The treated parts will have black color
finish.
B.Harishankar, Friction Technologies
Balaguru Harishankar
- Bangalore, Karnataka, India
Sheldon -
There are a few Heat Treat shops locally that would probably let you
try a test piece ( or two) at no charge. I would look in the yellow
pages under Heat Treating-metal to find out who they are.
Justin Stewart
- Surrey, BC Canada
This sounds like the kolsterising process to me, which seems to be
a carburizing process.
Jeroen Heijneman
- Zevenaar, The Netherlands
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
