Letter 36083
Electropolishing of cobalt alloy medical
device [South Africa]
Hi All
I am a student involved in a research project in conjunction with a
medical device company trying to develop an electropolishing process
for small tubular medical implants made from a cobalt-chromium alloy,
and have a number of questions that I hope you experts can help me
out with! I use an electrolyte consisting of 85% phosphoric acid and
glycerol, voltage control at around 7V, temperature around 70°C,
mild mechanical agitation.
1. I have heard, and have some limited experience that electrolyte
age affects polishing quality, and would like to monitor this. Which
is the best method (and most common and reliable economical industry
practices?): pH, conductivity, titration for specific elements,
specific gravity, viscosity, amp hours? My electrolyte will typically
go from clear to green to black.
2. Many of my problems occur at the contact between the anode rack (I
have used various geometries including plates and rods of both 316L
and titanium at different times) and the product (which is entirely
submerged). If the product is stationary it creates wave-like ripples
at the contacted surface. If I continually rotate the contact I
frequently get "volcano"-like features ("hills" with a burst-blister
appearance in the centre, although they are sometimes irregular).
Intermittant conact provides a combination of the two. Any
suggestions for avoiding these features, or an explanation for the
volcanoes? I can't lower voltage if all else stays the same because I
am very near the etching region as it is.
3. The edges of the product frequently get attacked and have a
bread-knife type pattern I have called mouse-bites (although these
are smooth features, unaccompanied by pitting or etching). Increasing
the temperature and voltage to 90°C and 10V improves this to
some degree but creates other problems like pitting and localised
attacks. Does anyone know why this happens and have a solution for
it? It also typically occurs on the surface at which contact is
made.
I would appreciate any help with any of the questions.
Ken Park
Engineer - Cape Town, South Africa
Try 75% commercial phosphoric acid (the 85% grade), 25% conc
sulfuric acid, 100F, 50-100 asf, copper contacts ( tight), control
metal below 3% wt in solution, specific gravity 1.7+, no intentional
agitation.
Jeffrey Holmes,
CEF
- Spartanburg, SC, USA
I am not as experienced to be called "an expert" at least not in
this alloy, but I humbly offer you the following comments,
Good anodic electrical contacts is critical. Titanium or Stainless
steel are not very good conductors for this task. Maybe you should
try copper just as Mr. Holmes recommends. However you hear very
worried about the bath metal content (Some copper will dissolve). I
wonder if anybody have tried gold or platinum contacts. These might
be noble enough to avoid its dissolution. Most of your problems sound
like you have to improve electrical connections. Anyway, please keep
us informed on how you solved the problem.
Regarding volcanoes, I wonder if they are what is so-called "Bull's
eyes" which are caused by gas bubbles... The wave-like ripples sounds
like also be caused by gas bubbles, which deteriorates the diffusion
layer in its path when ascending to the surface. Bad electrical
contacts also sometimes cause excessive gassing.
You don't mention anything the times you used... Sometimes increasing
current-density/Voltage and decreasing time helps.
The quality of the raw material also plays some role. There might be
metallurgical differences regarding the direction in which the metal
was either cast, annealed, machined or mechanically formed. Metal
grains and inclusions can be of different composition/size/shape in
certain zones of the part and it manifest as irregular finishing
during electropolishing, specially at the edges. I am not telling you
this is the case, but you should check this, just in case.
Finally, the preparation technique of part before electropolishing is
a commonly overlooked aspect. Are there pre-finishing steps, like
sanding or buffing? Do not think that electropolishing will clean the
part. Extensive cleaning, descaling and careful handling must be done
on the part, not just a simple detergent immersion. Check your alloy
chemical compatibility with strong acid/alkaline cleaners. Handle
parts with clean, intert, and powder free gloves or handlers. Avoid
any grease and dirt, even that form the skin. Certain contaminating
particles cause polarization in the surface during electropolishing
such as the abrasives from previous work, rendering pitting,
deformities or excessive gassing (Gas bubbles).
I wish you good luck and keep us informed on your findings.
Manuel Sández
- Hermosillo, Son. Mex
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
