finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 36066
Aluminum Composite Panels
Hi, I want to know what is the polyester coated aluminum composite panels?
What it means Polyester coated?
Alejandra De Anda
Frank Architects - Laredo, Texas
It probably means painted with polyester resin paint or powder coated with polyester resin powder.
finishing.com
Brick, New Jersey
Alejandro,
I tried to powder coat these once, but they came apart in the oven so they are probably wet painted.
Sheldon Taylor
   supply chain electronics
Wake Forest, North Carolina
If it's the same material as we use in the sign industry ACS (aluminium composite sheet) the polyester probably refers to the core.
ACS is two sheet of Aluminium coil- normally between 0.40 & 0.70mm.
The coils are pre-finished- not sure how. Some ACS is solid coloured so I presume it's wet painted. On the other hand some ACS is metal or stone effect so this isn't paint.
If you need ACS in a definative colour there are various options;
1) Flood coat with self adhesive vinyl of the appropriate colour.
2) Wet spray
3) ACS manufacturers will provide you with virtually any RAL colour subject to a minimum quantity.
Hope this helps,
Andy
- Dorset, UK
