Letter 36026
Powder Coating vs. Epoxy Painting
I have a quick question about the pros & cons of powder
coating and epoxy paints. We are installing guards around a shaft in
our underground potash mine. The area is very damp and highly
corrosive (salt water). There is no UV or sunlight in the area and
the ambient temp. is a stable 80 degrees. The guards also have a very
high risk of being contacted with equipment and tools (chipped).
Taking all of this into consideration, which would you suggest or
what type of covering would be the most appealing for this
situation.
Thank you very much for you help
Greg J. Gauld, EIT, BASc.
potash - Saskatoon, Saskatchewan, Canada
I would recommend you to go in for powder coating as the coat has
a better life and abrasion resistance as it is a harder coat. The
limitation is that the guards will have to go through a the coating
process including curing at 150 deg C.
Ryan Dmellow
- Mapusa, Goa, India
The coating might not be as important in this case as what the
guards are made of. A base material that won't corrode or easily
damage with a mil-spec for the paint would probably give you what you
want.
Sheldon Taylor
supply chain electronics
Wake Forest, No. Carolina
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a
new question or inquiry on a
different subject.
