HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 36007
STEP test problem in Duplex Ni Plating Plant
+++++We are not achieving Potential Difference ( STEP Value ) between two layers of Nickel - Semi Bright and Bright . The solution is already purified by Carbon , High pH ,Oxidation treatment. Sulphur content in Semi Bright is 0.002 % and )0.04 %in Bright solution. Request ur advice.
A.K.Kansal- India
The pH of the semi bright nickel should be 0.5 lower than the bright nickel.
Hello Sara,
We have gotten used to mantaining the same pH in both baths on account of adhesion issues with the lower pH in the SB.
Khozema Vahanwala Saify Ind Bangalore, Karnataka, India |
You can operate your SB at PH-4 and your bright nickel at
4.5.
I still cannot understand what does it have to do with adhesion.
Hi There,
If Everything is in order as termed to ph , sulphur content , temp, bath chemistry , then the things wrong may be with the additives used in semi-bright nickel, request for a special additive to increase the potential difference in semi-bright nickel just check in hull cell adjusting the make up and maintenance additives, please also look for the rinses and filtration before semi-bright and try to improve filtration in semi-bright.
Praveen Kumar plating process supplier Mumbai, India |
Dear sir,
Only sulphur is not criteria you need to check Impurity level as well
.Step is mainly depends on semi-bright as well as bright additives.Talk to your supplier.
Vishwas Nangare motorcycle accessories mfgr. - Aurangabad, Maharashtra, India |
dear sir,
first u see in hullcell panel,it must be semi bright effect(HCD dull LCD little bright).if it is totally bright than pls. add STEP bosster with initial additive.dont use maintaince additive till semi-bright effect u get.& continous run filter with carbon.
it is definetly give u best result with STEP TEST.
THANK'S
VIJAY
- mumbai,maharashtra,india
January 13, 2012
I also face same problem (STEP test value). In our plating shop, some of the chemical can be analyzed (basic salt, leveller, pH). However, we don't know how to check maintenance additive which gives the STEP reading. Supplier not help much on this issue. Our plating thickness for semi bright is 1.5-2 micron and Bright Nickel 3.5-4 micron?
Is it ok?
As far as i know, if ratio between Semibright and bright Nni thickness too far, you can get high step reading, but the potential graph will not good enough to be use.
On carbon treatment to remove sulphur, does it work? Another issue with carbon treatment is, it will remove other additive too (leveller, wetter).
- Malaysia
January 18, 2012
Dear Norddin,
Absolutely your thickness is too low and the opposite from normal practice (lower thickness on semibright nickel and higher thickness on bright nickel).
Normally in automotive field, people plate Semibright Nickel almost 1:1, f.e 10 microns Semibright and 10 microns Bright Nickel with total 20 microns,
but some people plate with total thickness 25 microns, then they use 15 microns Semibright nickel and 10 micron bright nickel.
In your case I think total thickness just 5 - 6 micron, to have single layer with 10 micron is better than duplex nickel (corrosion resistance low, and brightness not enough).
STEP value is depending of the type of additive, ask your supplier, in old days <100mV is enough but nowadays must be > 100-140mV as I heard.
For improving STEP, some branded suppliers got tools called STEP repairing additive.
Mostly STEP went down due to heavy load of organics in Semibright nickel (hullcell looked strange), either from pre-treatment (cleaners) or Leveler additive or Wetting agent.
Just do carbon treatment in semibright nickel solution (some branded supplier called Active Aids) and in my older time we can put a bit formaldehyde in semibright nickel solution to improve the STEP (test in hull cell bit by bit and you can see the hullcell pattern will come back as normal), but I don't know whether it's allowed or not right now.
Best regards,
Tony Chandra
Indonesia
- Jakarta, Indonesia
February 1, 2012
Thank you Mr. Tony, really appreciate your time to give feedback on my problem.
I would like to ask further on the thickness ratio between Semibright and Bright Nickel. Is it still same if later process after bright nickel is Satin Nickel?
If not, what is the best ratio between Semibright, Bright Ni and satin Nickel for automotive part? In my opinion satin nickel does not influence much on the STEP test reading.
regards
- Johor Bahru, MALAYSIA
